gtushar
Can I not use vivado 2017.4 synthesis feature with 2018.10 License ?
I have a license version limit 2018.10
Can I not use Vivado 2017.4 with this version limit?
hj
Yes. You can use 2017.4 synthesis feature if you have a license which has version limit of 2018.10.
Here is the AR https://www.xilinx.com/support/answers/33770.html
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
gtushar
No, it didn't work for me. I had to install vivado 2018.
