Observer s-kaku
Can Vivado 2017.4 Lab Edition be installed on 32bit system?
I have a question about Vivado 2017.4 Lab Edition.
In the release note, it's descrribed "Note: Lab Edition installer can be run on both 32 or 64-bit machines."
I downloaded 2017.4 Lab Edition(Xilinx_Vivado_Lab_Win_2017.4_1216_1.tar.gz) on 32bit machine, but after exeution of xsetup.exe, the error occurred.
"This installation is not supported on 32bit platforms"
Vivado: 2017.4 Lab Edition
OS    : Windows7 SPI Professional 32bit
If there is any way to install Lab Edition on 32bit machine, please let me know.
From the view point of valiation of supported SPI ROM, I want to install vivado after 2017.4 ver.
Kaku
Re: Can Vivado 2017.4 Lab Edition be installed on 32bit system?
Hello @s-kaku,
This executable is a 64-bit executable and not 32-bit.
Please note that the lab edition cannot be ran on 32 bit and this statement in UG973 (v2017.4) is incorrect.
There was a Change Request filed against the doc to remove this Note.
In the latest UG973 (v2018.1),  https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug973-vivado-release-notes-install-license.pdf, this note is no longer there.
Therefore, these days you can only install lab edition on 64-bit OS
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @s-kaku,
Kind Regards,
Anatoli Curran,
Observer s-kaku
Dear Anatoli,
Thank you for your reply and detailed explanation!
I see. I will try to prepare 64bit machine and install it.
Kaku
