Can not download Vivado.
Hello, can not download Vivado, writes " please correct the errors and send your information again.
We cannot fulfill your request because your account has not passed the export compliance check."I live in Belarus, I am in Egypt
Re: Can not download Vivado.
Furthermore due to strict export control policy, it is no longer possible to create or to maintain an online account in some E or D category countries. See here for more information
https://www.bis.doc.gov/index.php/documents/regulation-docs/2255-supplement-no-1-to-part-740-country-groups-1/file
In order for your profile to be reset and cleared, please send an email to Xilinx Customer Support (websupport@xilinx.com) indicating your "export compliance issue" and they in turn will contact Xilinx Customer Service on your behalf, who would be able to screen and verify your profile and re-activate this then, so that you can login and download the required software without issues.
https://www.xilinx.com/support/answers/44043.html
Egypt and Belarus I think are in band D, which Xilinx as a US company can not export to.
Ie I can not use Vivado Yes?
Xilinx cant down load it to you ,
It sup to you as to if you use any program or not,
Okay, can I download Vivado here or not?
from what I read, please check with the US department referanced in the links we posted,
    you are in a cat D area, so Xilinx can not download the code to you.
Its outside Xilinxs hands if so.
There is an email addres son the link I posted also, if you want to contact xilinx ,
Mentor
Mentor
j.svetlovich@gmail.com You can't download/use Vivado.
If you just want to experiment with FPGAs, Lattice chips have an open-source toolchain (and even their main toolchain might be available in Egypt) - but they're much less powerful.
I know. I need powerful solutions, for radar systems, with a nice program.
