muneebziaa
Can not lauch xilinx 14.2 licenses exe
Hi experts
i have just insatlled xilinx 14.2 to my window xp 32 bit, installation is completed without any problem but my linceses file is not attaching because the MANAGE XILINX LICENSES is not launching. HOW SHOULD I FIX THIS PROBLEM?
Muneeb
muneebziaa
Hi austin
I have a licenses file in my software but my XLCM manager is not working, how should I launch it?
Muneeb Ziaa
vuppala
the issue may be due to XLCM has not been included in the operating system PATH variuable. XLCM is located in $XILINX/../../common/bin/nt directory. Try adding $XILINX/../common/bin/nt to the PATH variable.
