Visitor sak110473
Can't load and activate license in Vivado
I created a licence for arti 7 FPGA, but can not get vivado to accept the licence.
Re: Can't load and activate license in Vivado
Hi @sak110473,
What issue are you facing while setting up the licence? Please refer to AR#38293 to understand the process of setting up the node locked license.
Chinmay
Visitor sak110473
I have tried that. And it still not working
Hi @sak110473,
Can you please  attach your license file (Xilinx.lic) and xinfo (to generate xinfo: Open Vivado > run "report_environment -file xinfo.txt" from tcl console)?
regards,
Chinmay
Visitor sak110473
Could you please explane it a little better?
HI @sak110473,
Please share the xinfo.txt file that gets generated after executing the command report_environment -file xinfo.txt in Vivado TCL console.
Visitor sak110473
Can you please tell me how and where to find that.
Hi @sak110473,
After opening Vivado, at the bottom, there will be a tab Tcl Console from that Tcl console tab execute the command report_environment -file xinfo.txt as shown in the below snippet.
once the command gets executed successfully you can use the pwd command to check where the report has been generated.
