Can't obtain a new license
my license ran out a few weeks ago and I'm trying to renew it. Sadly I always get the message like on the picture below, when I try connect through the license manager. I already tried to get a new license from the website, but the same error results.
Thanks for your help
Best Regards
HI @chris_inf,
Maybe try the direct link to generate a new license file
http://xilinx.com/getlicense
Then you can load the license in Vivado License Manager or put it in a known location and pint to it in VLM
Hope that helps,
Florent
HI @chris_inf,
Hope that helps,
Florent
It's working now. Clearing the browser cache helped for me!!
