Can't sign in Product Licensing page -TLS security
Hi, everyone,
I want to try a IP license on product Licensing page,but today after i finsh and confirm my Name and Address Verification and click on "next" button, the Browser tells me Failed to establish a sec.ure connection. This may be because the site uses expired or unsafe TLS security settings.The connection to the server is reset when the page is loaded(Both in Edge and firefox browsers)
.So how can I sign in license page to get my license?
Thank you
Re: Can't sign in Product Licensing page -TLS security
Hello @yaoyaobaobao,
Indeed, this is due to your Internet Explorer setting.
You should be able to open Internet Options->Go to Advanced tab ->scroll down to find Use TLS (as shown below)-> Select  Use SSL 3.0, TLS 1.0/ 1.1/ 1.2 ->Apply changes->OK. Then reload the page, and you should be good to go then.
If these are greyed out, please search on the Internet and there are a few workarounds that you can apply to get these enabled for you. Simply search for "Use TLS 1.0, 1.1, 1.2 greyed out or disabled" and you'd get a workaround for this.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Community Manager
Community Manager
Hi @yaoyaobaobao,
Have you tried a different browser? Another option to try is to sign out of all Xilinx sessions, clear the WHOLE browser cache and restart the browser.
Thank you,
Devin
Hope this helps.
Kind Regards,
Anatoli Curran,
