Can two users work together with a Node-Locked license on a single Linux machine?
I am working on a KC705 project with another engineer at my place of work.   If I install the Vivado license on one linux server (Node Locked, Device Locked) can we both use the software together, or at least one at a time from different user accounts?
Stephen
Stephen
Re: Can two users work together with a Node-Locked license on a single Linux machine?
Hi Stephen,
Are you installing the Xilinx tools on the linux server?
Vinay
Yes. The Xilinx tools not the fpga board. Thanks.
Stephen
Hi Stephen,
In that case, one can login to the server and run Xilinx tools at a time.
Vinay
Thanks!
Stephen
Hi Stephen,
If your query is answered, can you please close this thread by marking the correct post as "Accept as Solution"
Vinay
