sezermemis
Cannot Select Digilent Boards
Hello everyone. I am new at FPGA design. I installed Vivado but i cannot select board which i want. I guess it is license issue. But i don't know how i should install Vivado correct way. I am using WebPack Edition. I tried "install/update boards" button, adding boards manually but i cannot add. During the installation, 7 series boards are passive. I can't select. My professor says he use WebPack Edition too. But he didn't encounter same problem. Vitis, HL Design, HL System doesn't matter, which one i choose they are passive as in the following picture. What should i do?
 Thank you already!
miker
@sezermemis
Just a thought... what device family are you targeting?  Vivado 2020.3 is a release ONLY for Versal device family targets.
Have you tried uninstalling Vivado 2020.3, installing Vivado 2020.2, and using the default method for XHub Store downloads (i.e. don't copy any board files into the Vivado installation directory)?
Please Reply, Kudos, and Accept as Solution.
barriet
I don't initially think this is a licensing issue... You don't say what board you are using or the corresponding part/device but I suspect most of them are smaller WebPACK parts that won't require a license to target... And the license doesn't control the device install options - the installer and the licensing are actually fairly decoupled.
I don't use the Digilent boards but I don't see them in my 2020.2 install either... If you check their documentation, you'll see they have you download the board files from their repo and then install it into the tools, e.g.
https://reference.digilentinc.com/vivado/installing-vivado/start
That's probably the step you are missing.
sezermemis
Thank you for answer but I made the instructions on the web page you mentioned. It didn't work.
dpaul24
@sezermemis ,
First of all it is not a licensing issue.
You need to install the board files for Digilent. To do so, follow this tutorial-
https://reference.digilentinc.com/reference/software/vivado/board-files?redirect=1
Or this one and go the end of the webpage - https://reference.digilentinc.com/vivado/installing-vivado/start
------------FPGA enthusiast------------
Consider giving "Kudos" if you like my answer. Please mark my post "Accept as solution" if my answer has solved your problem
miker
@sezermemis
You download boards separately from the Vivado installation.  Once you have your Vivado installed, select Tools > XHub Stores...
An XHub Stores window will appear and you can then select the Boards tab > expand the Digilent Inc listing, select the desired board, select the download icon.  You should now have the boards available to you.
sezermemis
@miker @dpaul24  Guys as i said twice before, i did your advices when i encounter this issue. Nothing happens. There is something different.
miker
@sezermemis
Sorry, I'm not sure what your issue may be.  I don't believe you followed my instructions as it would not install in the Vivado installation directory as you showed.  It would install in your Windows AppData directory in a directory structure similar to the following.  For example, the Digilent Arty A7-35 downloaded in Vivado 2020.2.
C:/Users/<username>/AppData/Roaming/Xilinx/Vivado/2020.2/xhub/board_store/xilinx_board_store/XilinxBoardStore/Vivado/2020.2/boards/Digilent/arty-a7-35/E.0/1.0/
You can check your Tools > Settings... and verify the location of your XHub Store > Board Repository location.  Considering you just installed the tools, I would expect the default directory structure as I showed.  You could try pointing the Board Repository location to your C:/Xilinx/Vivado/2020.3/data/boards/boards_files but I would suggest not ever downloading files into the installation directory and just use the default repository location for managing boards.
sezermemis
I did. You can see in the screenshot.
 In my first message, during the installation i can't select 7 series, SoCs, UltraScale etc. Because of this maybe it is license problem.
sezermemis
Looks like this
miker
@sezermemis
sezermemis
I tried to select cmod A7-15t board. I will uninstall 2020.3 and install 2020.2. Is it proper for my target board right?
miker
@sezermemis
Yes, Vivado 2020.2 is the current release for all device families (including the Artix-7 series you are targeting) other than Versal.
