Anonymous
Not applicable
Cannot use available floating license
Hello
I have setup a license server on a linux machine.
I have configured the XILINXD_LICENSE_FILE to point to the port@server .
The (windows) license configuration manager is able to connect to and identify the licenses available on the license server: ISE_Embedded_Edition, ChipScopePro_SIOTK, ChipscokePro, ISE, XPS, ISIM.
Also I see SDK, PlanAhead, Analyzer, Implementation, Simulation, Synthesis, Vivado_Design_Edition are TRUSTED STORAGE
I am trying to use the Xilinx ISE floating license.  Under Manage Licenses I see that License type is floating, License Count is 1, and Licenses In Use is 0.  I cannot seem to use the floating license for the ISE.
When clicking on the "Borrow/Restore Licenses" tab I see what appears to be the Vivado license listed as available to borrow.  When I select this license and click "Apply" I receive the error "Unknown error was encountered while performing the operation".
The lmgrd log file on the linux server reports:
"DENIED" "Vivado_Design_Edition" ACCTIVATED LICENSE(S) (Licensed number of users already reached)
"DENIED" Implementation" ACTIVATED LICENSE(S) (Licensed number of users already reached)
Really, I only want to use ISE, but I would think I would be able to borrow the Vivado license as well.
How do I get the license manager to make use of the ISE floating licnese?
Re: Cannot use available floating license
Hi @Anonymous
Can you share your license file here?
Share the lmgrd log file after trying to access the ISE license.
Vinay
Anonymous
Not applicable
# ----- REMOVE LINES ABOVE HERE --------------------------
SERVER LDIFS 7071bc3fc1a8 2100
USE_SERVER
VENDOR xilinxd /opt/flexlm/ port=2200
# This is a permanent license generated on Wed Jan 07 21:17:05 UTC 2015
INCREMENT SDK xilinxd 2015.10 permanent 1 DF6C68B3B15C \
VENDOR_STRING=ryan.hamel@digisonde.com,SDK,software,permanent,_210640200_1777503315_210589940_301 \
ISSUER="Xilinx Inc" START=07-Jan-2015 TS_OK
INCREMENT ISE_Embedded_Edition xilinxd 2015.10 permanent 1 \
5CE1165EC400 \
VENDOR_STRING=ryan.hamel@digisonde.com,ISE_Embedded_Edition,software,permanent,_210640200_1777503315_210589940_963 \
# The following PACKAGE definition is a REQUIRED part of this license:
PACKAGE ISE_Embedded_Edition xilinxd 2015.10 C40CC2C5EF4B \
COMPONENTS="ChipScopePro_SIOTK ChipscopePro ISE XPS ISIM \
PlanAhead" OPTIONS=SUITE
# ----- REMOVE LINES BELOW HERE --------------------------
12:33:44 (xilinxd) DENIED: "Vivado_Design_Edition" ACTIVATED LICENSE(S)@Hamel-LT2 (Licensed number of users already reached. (-4,342:2 "No such file or directory"))
12:33:44 (xilinxd) DENIED: "Implementation" ACTIVATED LICENSE(S)@Hamel-LT2 (Licensed number of users already reached. (-4,342:2 "No such file or directory"))
12:33:44 (xilinxd) IN: "Analyzer" ACTIVATED LICENSE(S)@Hamel-LT2
12:33:44 (xilinxd) IN: "Vivado_Design_Edition" ACTIVATED LICENSE(S)@Hamel-LT2
12:33:44 (xilinxd) IN: "SDK" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) OUT: "SDK" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) OUT: "Vivado_Design_Edition" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) OUT: "Analyzer" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) DENIED: "Vivado_Design_Edition" ACTIVATED LICENSE(S)@Hamel-LT2 (Licensed number of users already reached. (-4,342:2 "No such file or directory"))
14:06:04 (xilinxd) DENIED: "Implementation" ACTIVATED LICENSE(S)@Hamel-LT2 (Licensed number of users already reached. (-4,342:2 "No such file or directory"))
14:06:04 (xilinxd) IN: "Analyzer" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) IN: "Vivado_Design_Edition" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:04 (xilinxd) IN: "SDK" ACTIVATED LICENSE(S)@Hamel-LT2
14:06:20 (lmgrd) TIMESTAMP 10/28/2015
14:11:55 (xilinxd) OUT: "ISE_Embedded_Edition" hamel@Hamel-LT2
14:11:55 (xilinxd) OUT: "ISE" hamel@Hamel-LT2
14:11:55 (xilinxd) IN: "ISE" hamel@Hamel-LT2
14:11:55 (xilinxd) IN: "ISE_Embedded_Edition" hamel@Hamel-LT2
14:12:00 (xilinxd) OUT: "ISE_Embedded_Edition" hamel@Hamel-LT2
14:12:00 (xilinxd) OUT: "ISE" hamel@Hamel-LT2
14:12:00 (xilinxd) IN: "ISE" hamel@Hamel-LT2
14:12:00 (xilinxd) IN: "ISE_Embedded_Edition" hamel@Hamel-LT2
14:26:33 (xilinxd) TIMESTAMP 10/28/2015
Hi @Anonymous and @Anonymous
From the log file, it looks like there are NO issues in accesssing ISE license features. See below lines:
Vinay
Anonymous
Not applicable
Yet I am unable to use features that are non-web pack.
I am not able to create a project making use of a Virtex 5 FX130T device, for example.
Which version of ISE are you using?
Nupur
Hi @Ryan,
Which ISE edition have you installed? (System Edition, Webpack edition or Embedded edition).
Please check the same in the xinstall.log file in .xinstall folder of ISE installation.
If in case it is Webpack edition, then the mentioned device (Virtex 5 FX130T ) is not supported.
(Refer to this link for list of supported devices : http://www.xilinx.com/publications/matrix/Software_matrix.pdf)
Rajesh
MARK this is as accepted solution if in case it helped resolve your query/issue.
