CentOS/RHEL 7 Xilinx package requirements?
Install,
I am working through a new install with CentOS7 (could do RHEL 7 if necessary).  Now I was given this machine which was configured by others and have discovered that it is lacking in the "required" packages.  Which I can only find through trial and error?  So is there a piece of documentation which outlines the minimum necessary configuration?  I do know such a thing exists for PetaLinux (it is long but doable) but haven't found one for Vivado.
Thanks so much for the support,
TomT...
Re: CentOS/RHEL 7 Xilinx package requirements?
Hello @tessitd,
Have you checked this Answer Record yet?
https://www.xilinx.com/support/answers/66184.html
This should include what you are looking for, as it show you what/how to check which required library or libraries are missing on a Linux system.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Bump?
Hello @tessitd,
Hope this helps.
Kind Regards,
Anatoli Curran,
Hello @tessitd,
This topic is still open and is waiting for you.
If your question is answered and/or your issue is solved, please mark a response that resolved your issue, as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions). This way, the topic can be completed then.
If this is not solved/answered, please reply in the thread.
Thanks in advance and have a great day.
Kind Regards,
Anatoli Curran,
