Chroma Resampler license
i'd like to get the xapp1167 working but I'm stuck at the synthesis. When I report IP status and look at the IP's most are for free, some purchased (for example Video Timing Controller) and there is the Chroma Resampler.
this license is: Hardware_Evaluation. I am not sure what this means, or how to get it. Do I get it when I activate the code for the zc702 board or do I have to purchase it additionally? Or is there a way to get it for free?
Please help me,
regard,
lunarix
Re: Chroma Resampler license
Hello @lunarix94-
Check this answer records: http://www.xilinx.com/support/answers/42380.html
http://www.xilinx.com/support/answers/42068.html
Vinay
Hello @lunarix94-
Vinay
Hello vuppala,
thanks for the fast reply. So i do not have to buy anything, just get a new bitstream every few hours?
then thats not my problem why the synthesis fails... :/
regards,
lunarix
Hello @lunarix94-
Can you share the exact error message?
Also share the generated file after running the following tcl command in Vivado Tcl console: report_environment -file xinfo.txt
Vinay
Hello vuppala,
here is the link for the topic I did few days ago. there is my question and the file and error:
https://forums.xilinx.com/t5/Synthesis/XAPP1167-synthesis-error/td-p/676255
thank you,
lunarix
Hello @lunarix94-
In both the attachments i.e., vivado.txt and runme.txt, I didnt see any error message about licensing.
in Vivado.txt, the error is due to port connections.
In runme.txt, the error is due to module missing.
Vinay
the first one was solved when I got vivado 2013.3.
So do you have any solution for the 2nd one? I thought there might be something broken because synthesis stops.
but why should there be a module missing?
greetings,
lunarix
Okok i got the error.
It's written in this topic:
https://forums.xilinx.com/t5/Design-Tools-Others/ERROR-Ipptcl-7-5-XIT-evaluation-error-File-writer-encountered-an/td-p/448090
I thought it does affect me because i had only 256 lines and not 259+, but somehow that was my issue. I placed the whole project at C:\ now and the synthesis works.
