Observer rendres
Color Filter Array Interpolation licensing error
Hi!
I'm using a Zedboard to develop a video channel with the OV2640. I'm trying to work with the sensor (as I can't make the DSP convert to RGB565) and I need to use the CFA IP to interpolate from bayer BGGR to RGB. I've seen there is an evaluate version of the IP that longs 120 days so I generated the Xilinx.lic file. The problem is that the VLM finds the license for the IP Core but Vivado tells me that I don't have a valid license for this IP.
I've tried to link the XILINXD_LICENSE_FILE in the bashrc and once again the VLM finds it but still have the same problem. As a zedboard owner I can use the Vivado Design Edition with ZC0720, but can't use this IP neither.
What steps can I follow to make Vivado 2016.4 recognize this IP as valid? I've started to think that I can't use the Evaluate version to generate a bitstream...
P.D. Working on Ubuntu 14.04.
Thanks!!
Tags (4)
Observer rendres
Re: Color Filter Array Interpolation licensing error
Hi!
Finally solved it, the problem was that my local network was not named eth0 so Vivado didn't match the MAC Address of my Ethernet to the one in the .lic
Thanks !!
check this ARs
https://www.xilinx.com/products/design-tools/faq.html
Thanks and Regards
Balkrishan
Hi @rendres,
Can you please share the snapshot of the complete error message?
Also share the xinfo.txt.
You can generate xinfo.txt by running the following  tcl command in Vivado tcl console:
report_environment -file xinfo.txt
Sravanthi B
Thanks & Regards,
Sravanthi B
Observer rendres
I have attached the screen shot with the Vivado error and the xinfo.txt generated with the report_environment -file xinfo.txt command
Thanks!
Observer rendres
Hi!
Thanks !!
Visitor chrislee2
Can I know how I can change the local network?
I downloaded the node-locked license for color interpolation but, VIVADO stills says that license is needed.
I think issue is with local network. Please tell me how I can change the local network.
Thank you.
