petgu
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z010'
I get the following error message when I try to synthesize:
"[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z010'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
I cant return my license, when I try VLM says: "invalid option specified".
I cant manage licenses in the vivado webpage, the option is greyed out.
Running "report_environment -file <directory_name>/env.txt"   in the tcl log generates the attached file.
It looks like something is wrong but I dont now how to fix it.
I have made exceptions in my virus program for Xilinx related products.And I have tried with the firewall off.
I have the free WebPack version.
It worked fine for a couple of hours after I got the licenses, synthesis, simulating, implementing and generating bitstream.
Looking in VLM under view license status I think there was three activation based licenses from the beginning, I cant remember what they were called but currently there are just two called "Embedded_SDK" and "Vivado_WebPACK".
I run Vivado 2014.4 on windows 8.1 64-bit.
Would be great if someone could help me get going again.
Thank you!
ashishd
Can you please follow below steps and share the result.
1. Open windows command prompt and navigate to <VIvado_installation_directory>\bin
2. Type command : xlicclientmgr -v "format=long" and share the output
3. Type command : xlicclientmgr -l and share the results
Ashish
petgu
The results are attached.
Peter
ashishd
Hello @petgu,
From the output of these commands, it seems like the trusted storage on your machine is corrupted (there can be several reasons for it). To recover the trusted storage please refer below thread -
http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-License-Manager-will-not-allow-me-to-return-license/td-p/527697
Ashish
seanz
Hi Peter,
It seems your Trusted Storage has been corrupted. For the possible cause of this problem please refer to:
http://www.xilinx.com/support/answers/63683.html
You may need to regenerate and re-install your license.
As you are using free licenses, which can be found in every Xilinx account, you can easily generate a new one.
Sean
