ccdoss
[Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xcvu9p-es1
I've downloaded a sample design which is set to use the XCVU9P part. I've got a valid license for it, but Vivado is refusing to run. I've seen other posts, and it seems to point to the use of Vivado_HLS vs Vivado. I believe my license is for Vivado.
ccdoss
I was able to identify the problem. I had to run the application as root as Vivado couldn't see the boards otherwise. However, the license was installed as another user. When Vivado looked for the license, it didn't see it. I ran the license manager as root and reran Vivado. It now works.
shameera
Hi @ccdoss,
As, you are targeting the design to Engineering Sample device (es1). I would suggest you to get the license of xcvu9p-es1.
Thanks & Regards,
A.Shameer.
florentw
Hi @ccdoss,
You should change the project target to xcvu9p production silicon (not es1 or es2). Then it will work (it is harder to get an es1 silicon and this is unlikely that you will get it if you don't have an ES1 silicon).
Florent
Florent
ccdoss
I am not seeing an option to select a typical production part. It is either es1 or eval. When I specified eval before, I got the same error.
ccdoss
florentw
Hi @ccdoss,
Thank you for sharing your observations.
As the issue is fixed, could you mark this issue as solved by marking a response a solution?
Florent
Florent
