mduprez_mutest
[Common 17-345] A valid license was not found for feature 'synthesis' and/or device 'xcku060'
We are running Vivado 2018.2 using floating license and cannot run synthesis on xcku060.
The server does not have Vivado installed, only the license utilities . Flex net version is 11.4 as requested. "8:15:17 (lmgrd) FlexNet Licensing (v11.14.1.0 build 194335 i86_n3)"
When opening the Vivado License manager on the Client, it shows the 2 license available, but Vivado says it cannot get one (either synthesis, either targeted device xcku060) (see picture of VLM and Vivado together)
Taking a look at the lmgrd log on the server (extract joined), I have some message saying that the synthesis license was granted, but apparently, there is an issue with the device (UNSUPPORTED: "xcku060" (PORT_AT_HOST_PLUS   )
Running from another computer/client, I was able to perform to get license and perform synthesis with xcku060, but the design was so small (only assign my_out = my_in;) that may be Vivado did not car about the licensing. when running from this computer, I had the same logs in eg picking a synthesis license but error with the xcku060. However, the project was synthesized and implemented.
I have the following questions:
- Is the part type (xcku060) validated through the license on the Server or through the Vivado version on the Client ?
- the computer/Client having issues is 'old' and had many demo/free license for different Vivado/ISE version. Can it be an issue (the .lic file have been removed from the search path) ?
- Any idea to fix our problem ?
Thanks for any help you can provide
Mathieu
mduprez_mutest
Hello Anatoli,
Please see attached the lmstat results.
lmgrd is UP on the license server,
xlinxd is UP on the license server as well.
Best Regards,
Mathieu
hemangd
Hi @mduprez_mutest,
Provide your Vivado license file (.lic) to evaluate.
And also run "report_environment -file <filepath>/env.txt" in tcl console and provide env.txt to evaluate.
Also mention the full device part name which you are targeting.
hemangd
mduprez_mutest
Hi hemangd
Thanks for any help you can bring. Attached are the lic and report file.
The targeted device is :  xcku060-ffva1517-1-c
Best Regards,
Mathieu
anatoli
Hello @mduprez_mutest,
We can see your floating license server is up and running with lmgrd v11.14. However, is the version of xilinxd is also v11.14?
Can you please open a command prompt and CD to the location such as e.g.: C:/Xilinx/Vivado/2018.2/bin/unwrapped/win64.o
Then, from here, please run this command: lmutil lmstat –a –c <port_number>@<server_name> (in your case the command would be as followed: lmutil lmstat –a –c 2100@192.168.0.50)
Then please see if lmgrd is UP and xilinxd is UP too and then, see what version of flexlm utilities the server is/was started with? Do you see v11.14 for both lmgrd and xilinxd?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
mduprez_mutest
Hello Anatoli,
Best Regards,
Mathieu
mduprez_mutest
After observing that some of our project where OK to get a licence, we restarted the same project from scratch, calling for all the source files and libraries. The new 'projet' is able to get a license, synthesis, P&R. The project now works on the same PC that was failing to get a license.
I have no idea what was going on, but I will close the case as we can work.
Many thanks for your help.
Mathieu
