Compatibility of Vivado Webpack
Hi guys.
Short question...
Can I use these boards with the free Vivado Webpack?
BOARD DEV ZYBO ZYNQ-7000 | https://www.digikey.at/product-detail/de/digilent-inc/410-279/1286-1044-ND/4840864
or
CORA Z7: ZYNQ-Z7000 SINGLE CORE | https://www.digikey.at/product-detail/de/digilent-inc/410-370/1286-1203-ND/9445909
Thanks for every answer!
Cheers
Re: Compatibility of Vivado Webpack
Hi @fhwn_gradinger
Yes, you can use as long as the devices mounted on these boards are supported by Vivado webpack.
https://www.xilinx.com/products/design-tools/vivado/vivado-webpack.html#architecture
Rohit
Hi @fhwn_gradinger
Rohit
Thanks for the quick answer!!!
