Computer specs needed for Vivado design suite installation
What are the computer hardware and software specs that are needed to run Vivado design suite.
Re: Computer specs needed for Vivado design suite installation
I have an engineer here that says I will need to have a windows pc that has at least an I 7 Processor in it to run this design suite, especially the high level synthesis part. I don;t see that in any of the specs. Is this a requirement or what would be a suggestion?
Check page 8 of this link:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug871-vivado-high-level-synthesis-tutorial.pdf
Nupur
Accept as solution if it resolved your query, give kudos if it led you to the solution.
Nupur
