Converted from Webpack License to Node Locked license - update_mem still won't run
I had previously installed a WebPack license for Vivado 2015.1, but could not run update_mem for the FPGA in our design (xc7k325t). I just installed a node-locked license, and am still getting the same erro when I run update_mem:
ERROR: [Updatemem 57-44] xc7k325t device is not supported by update_mem.
I generated the attached log.txt file from the vivado tcl shell with the command
report_environment -file log.txt
How do I get update_mem to run?
Re: Converted from Webpack License to Node Locked license - update_mem still won't run
Can you please post your license file here?
Also, which OS are you using?
Nupur
Nupur
Windows 7 - see the log file for more system info.
License file is attached.
No one from xilinx able to respond? Unbelievably frustrating to pay for a license and not be able to use it...
Solved this by reinstalling Vivado. It wasn't enough just to upgrade the license, I needed to upgrade the installation too.
In Vivado's Help->Add Design Tools or Devices menu I saw the Webpack version was installed. Rather than upgrading the existing installation, I just uninstalled Vivado, downloaded the whole 4.78GB Vivado installation file, and reinstalled the Design Edition. The tools work now.
