Newbie avazula
Could not set the path for installing Xilinx ISE Design Suite
I'm trying to install Xilinx ISE Design Suite on my computer running Ubuntu 16.04, but I cannot go farther than the "Select Destination Directory". Indeed, I would like to set this path to /opt/Xilinx, but the wizard tells me that I "
have entered one of the following characters in the program group folder name:
These characters are invalid for folder names. Please re-enter a valid folder name."
I really don't understand this error. I deleted the folder and redownloaded the TAR archive but it led to the same error. I downloaded the archive from here, extracted it, and ran
sudo ./xsetup
in the extracted folder.
Could anybody help me with this please ?
Kind regards,
Ava
PS: I really need Xilinx ISE rather than Vivado since I'd like to code on a Spartan 3 FPGA.
Re: Could not set the path for installing Xilinx ISE Design Suite
Hi @avazula
The issue here is the OS which you are using is officially not supported by ISE.
Use supported OS based on the ISE versions which are mentioned in this Answer Record.
https://www.xilinx.com/support/answers/18419.html
In this way, you will overcome the unwanted and unknown errors.
hemangd
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
Hi @avazula
hemangd
hemangd
Newbie avazula
Hi @hemangd,
Thanks for your answer. I had a look on your link, and as far as I understand, I can't install it on Windows 10 either? Unfortunately, these are the 2 OSs I have.
Kind regards,
Ava
Hi @avazula,
Still you can try workaround for installing ISE 14.7 with windows 10 professional addition based in below mentioned link. (Note: windows 10 should not upgraded with creators update.)
https://www.xilinx.com/support/answers/62380.html
hemangd
hemangd
Newbie avazula
Hi @hemangd,
Thanks for the details. I installed a Red Hat system in a VM, I hope it'll be enough to run Xilinx on it. Otherwise, I'll try to install it on Win10 anyway.
Thanks again for your help,
Kind regards
hi , @hemangd,
i am having same problem,
i refer  your suggestion but still it's not solved.
My OS system is windows 7 pro and  it's mentioned in the ISE versions which i am trying to installing.
Could you help me with this please ?
Kind regards,
Shivam
