Visitor treczoks
Current Vivado on Current Linux?
I just treated myself to a new computer, and installed a current Ubuntu (18.4 Bionic Beaver LTS) on it. I tried to install a current Vivado (2018.2) on it, although it is currently only supporting Ubuntu 14.4. Well, it installed, but it didn't create any start menu item for it, and I only found an article that I would have to add the start menu items manually, without even telling what menu items I would need.
1. Are there any plans to bring Vivado to a non-antique Ubuntu platform?
2. Has anyone successfully gotten this to work in a recent or even current Ubuntu?
3. Anyone who has successfully added the start menu items: Could you share what is needed?
And no, I'm not going to scrap my current Ubuntu and go back in history just to run Vivado.
Re: Current Vivado on Current Linux?
Hi @treczoks,
Vivado 2018.2 is currently supported/recommended in Ubuntu Linux 16.04.3 LTS (UG973 page no.11). If this works in any other Ubuntu versions greater than this version, then that's good news (but one might face stability/design issues moving forward because of non-recommended platform as seen based on experience).
If there are plans to support Vivado in Ubuntu like 18.4 Bionic Beaver LTS in future, we will surely let all know.
I do not think Xilinx have tested Vivado 2018.2 in this version of Ubuntu 18.4 to be released as supported and recommended with tool.
Maybe if someone in community might have, they may help us with resolution to your problem.
Prathik
Don't forget to reply, kudo, and mark the appropriate post as 'accept as solution'.
Hello @treczoks,
Please check this Answer Record: https://www.xilinx.com/support/answers/56551.html in relation how to add shortcuts to the Start menu
Have you tried this already?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
