Después de descargar Vivado Design Suite no me abre ninguna ventana
HOLA ya descragué Vivado 2015 y 2018 en diferentes versiones descargo el .exe
lo ejecuta pero después no me abre ninguna ventana para seguir descargandolo.
Agradecería la ayuda.
Scholar watari
Re: Después de descargar Vivado Design Suite no me abre ninguna ventana
Hi ameyall@hotmail.com
What type of installer did you download ? Web installer type or Full installer type ?
Also, do you have a valid xilinx account ?
Hi.
I downloded web installer
I just created a account I don't know if this is valid xilinx account.
How can I confirm if my account is valid?
Scholar watari
Would you do the followings ?
- Make sure the status of "Windows Defender".
    Windows suspects this installer as like viruse.
- Enter your xilinx account and password, if installer require it.
Hello ameyall@hotmail.com ,
Are you able to download a full Single File Download installation files using this link (https://www.xilinx.com/member/forms/download/xef-vivado.html?filename=Xilinx_Vivado_SDK_2018.3_1207_2324.tar.gz) or are you seeing errors? Can you please give this a try and see if the required e.g. 2018.3 can be downloaded that way?
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Were you able to download the required software using a full Single File Download installation files? Can you confirm on this please? Thanks in advance.
Kind Regards,
Anatoli Curran,
