Do I need an AMBA license to design IP cores that interact with Xilinx IP cores?
According to the AMBA / AXI specification I need a AMBA license to design IP cores with AXI interfaces. Is that right? If so, how can I use Xilinx IP cores with AXI interfaces? How can I get such a license and how much does it cost?
Re: Do I need an AMBA license to design IP cores that interact with Xilinx IP cores?
Hi @paebbels
Get in touch with your nearest sales/distributir office for pricing and other information that you are looking for.
http://www.xilinx.com/about/contact.html
Thanks,Vijay
You dont need a special license for AMBA IP cores. Most of the Xilinx cores are AXI-4 complaint.
If a core is licensed, then you would need a license for that specific IP. But you dodnt need anything specific AXI compliance.
For Example: MIG Xilinx IP  is a free core an this can be implemented with AXI-4 interface.
Hope this helps.
Sikta
Hi @paebbels
Did that helped? If yes, close the thread by marking the solution in the interest of other users.
Thanks,Vijay
