Documentation on logicopt parameters in Vivado
i've managed to install vivado 2017.1 and the document navigation tool
but none of the documentation seems to be included in the 20GB download.
Is there a link or page I can use to download this for use on my non-internet
connected equipment please?
thanks
j.
@john321, how did you install Vivado (i.e. Web Installer or Single File Download) and which Vivado edition (WebPACK, System or Design) did you install?
Can you confirm whether Documentation Navigator was not installed (Start => All Programs => Xilinx Design Tools 2017.1 => DocNav => DocNav)?
@john321,
Open DocNav and click on Download manager button
Attaching the document (UG968) on using DocNav to this post. Check out "Download manager" section at page 9.
--Syed
Thanks for the replies
I installed everything from the full 20GB download (I'm evaluating the xilinx system to see if I can use it)
The machine it is installed on is not on the net and cannot be, so no online help is any use - I need to install all help documents on the local machine after intermediate anti-virus checks on another system.
What I'm looking for then is a downloadable help file.
(zip gz or whatever)
If this is configured for a server use only I can put it on
the local apache tree used on the development machines for this purpose - but I need the help/tutorial files locally not online.
@john321,
Check the following forum threads which guide on setting up docnav download files in offline mode.
https://forums.xilinx.com/t5/Design-Entry/DocNav-Catalog-Download/td-p/474002
https://forums.xilinx.com/t5/Installation-and-Licensing/using-DocNav-offline/td-p/477464
--Syed
Thanks Syed
I'll give the suggestions a go.
a zip of the Xilinx document tree would be very welcome though
if they are reading this.
