Newbie tonio1999.
Dont have full product download
 Hello, we've downloaded the Xilinx software installer, but all we currently have is just this license manager. We dont see any option to open the Xilinx program to use it. Is there additional software that needs to be downloaded or are we just not completing a step correctly? The image of the license manager is provided
Re: Dont have full product download
Hi @tonio1999.,
Please check this AR# link:
https://www.xilinx.com/support/answers/60117.html
Raj
Hello @tonio1999.,
If you've used Vivado WebInstaller, that means you most likely have installed Vivado tools, as you can't install Vivado License Manager on its own.
Is this a Windows OS? If so, to open Vivado, open a command prompt and CD to the location such as C:\Xilinx\Vivado\2018.3. From here run settings64.bat and then run a 'vivado' command as shown in my example below:
During the installation process you may have deselected "Create Start Menu and Desktop Icons". If that is the case, and if this a Windows OS, you can follow the steps in the following Answer Record to get these added for you:
https://www.xilinx.com/support/answers/56551.html
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
