Download link for WebPack
where is the Download link for the last stabile version of WebPack?
it is not a user-friednly website
Advisor
Advisor
@ovidiuo2000 It's the same download for WebPack, Design Edition, or System Edition. The only difference is what features get installed/licensed.
I don't think it's possible to provide a direct link for the download. There are a bunch of restrictions on Vivado (imposed by the US government) about who can download it, and for that reason Xilinx only provides the download after you've logged into a Xilinx account.
This is not a solution.
The first link leads to NO actual link for WebPack;
the second link points to  https://www.xilinx.com/support/download.html , but here there is no "WebPack".
I don`t want a description for WebPack.
I want to download the last stable version of WebPack.
@ovidiuo2000
On those pages, you should see the 'download' link. Click on that and you should be good to go.
Hope that helps
If so, please mark as solution accepted. Kudos also welcomed.
Advisor
Advisor
Hello @ovidiuo2000 ,
As correctly indicated above, once you begin the installation process, there will be an option what you'd like to be installed. One of the options there will be Vivado WebPACK edition. Selecting this will allow you and install Vivado WebPACK.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
