andreac_avnet
EF-VIVADO-SYSTEM-FL - Use in another country
I'm going to use the EF-VIVADO-SYSTEM-FL.
Is it possible to use it from another country if I buy 2 license seats ?
I'm based in Italy but one of colleagues is in Dubai and needs to work with the same license.
thanks in advance for your help.
Best regards,
Andrea
anatoli
Hello @andreac_avnet ,
Yes, that is correct.
If you buy 2 floating licenses, you can generate one FL license for your office in Italy and then generate a separate lic (i.e. the 2nd seat of the 2 FL licenses you have) for your other location/server in Dubai.
Alternatively, you can generate both of these 2 FL licenses for one floating license server/machine and set it up in your location in Italy.
If your colleague in Dubai has access to that same server/machine where you've installed these floating licenses, then all your colleague needs to do is to open Vivado license manager and set his XILINXD_LICENSE_FILE environment variable to point to that floating license server. He/she can then use a seat of these floating licenses that way too.
e.g.:
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
e.g.:
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
