helmut.rathgen
ERROR: [Common 17-1374] Display test failed. Please check DISPLAY environment variable and X server permissions for remote display
I have two up-to-date arch linux installations.
On one of them Vivado runs fine, on the other I get (since a package update run today) this error when I start vivado:
The display variable is set properly and is the same (on both installations).
Can you help me with further debugging?
Thank you for your help!
- Helmut
balkris
In you Linux OS, if you display the environment variable $DISPLAY you should get host name
You can try to change it to localhost as per $DISPLAY commend
Thanks and Regards
Balkrishan
helmut.rathgen
As I said, the DISPLAY environment variable is set correctly on both machines. Vivado works on one machine and doesn't on the other. So, it cannot be a problem with the DISPLAY environment variable.
msdarvishi
I just tumbled into this post while I encountered the same problem and I was looking for a solution for it.
Here is what to do in order to solve the problem. I just write it here for future users  to solve their problems quickly and save their time.
Pleasenote that in remote connection to another computer if you put the following command
ssh IP_addr_of_host_machine
you will get the ERROR message regarding the environment variable settings for DISPLAY.
In order to let the localhost to set this parameter, just run the following command
ssh   -X    IP-addr_of_host_machine
Now it works and you won't get the error message!
Enjoy!
MD
