Newbie valtuntas
ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture.
Hi everyone,
I installed ISE WebPack 14.7 version.
When I want to implement a design for Xilinx Spartan 3E Starter Kit, the error appeared such "ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture."
I did the web pack (free) licence procedures, how can i solve it?
Licence, project files and screenshot are attached.
Re: ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture.
It looks you applied for a Vivado WebPACK license rather than ISE WebPACK.
If you don't see ISE WebPACK license entitlement in your account, check you managed license tab, as mentioned in the following previous post.
https://forums.xilinx.com/xlnx/board/crawl_message?board.id=INSTALLBD&message.id=17438
Scholar austin
https://www.xilinx.com/support/answers/11630.html
Check your environment variables.  License needs to be where it is directed to find it.
Austin Lesea
Principal Engineer
Xilinx San Jose
Newbie valtuntas
i changed environment variables manualy and with the license manager but still i have the same problem
here is the output,
i am using windows xp pro. sp2
thanks
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc3s500e-fg320-4 -cm area -ir off -pr off -c 100 -o Testing_LEDS_map.ncd Testing_LEDS.ngd Testing_LEDS.pcf
Using target part "3s500efg320-4".
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:54 - 'xc3s500e' is a WebPack part.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to
'C:\Xilinx\14.7\ISE_DS\common\licenses\Xilinx.lic'.
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to
INFO:Security:68 - For more information or for assistance in obtaining
 a license, please run the Xilinx License Configuration Manager
       (xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is Administrator, on host VAXPSP2.
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available
for part 'xc3s500e'.
No such feature exists.
Feature:       WebPack
License path:
C:\Xilinx\14.7\ISE_DS\common\licenses\Xilinx.lic;C:/.Xilinx\Xilinx.lic;C:\Xilinx
\14.7\ISE_DS\ISE\/coregen/core_licenses\Xilinx.lic;C:\Xilinx\14.7\ISE_DS\ISE\/co
regen/core_licenses\XilinxFree.lic;C:\Xilinx\14.7\ISE_DS\EDK/data/core_licenses\
Xilinx.lic;
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "www.flexerasoftware.com".No such feature exists.
Feature:       ISE
License path:
Xilinx.lic;
   architecture.
Design Summary
Number of errors   :   1
Number of warnings :   0
Process "Map" failed
