dsej
ERROR - Map:258
error.JPGerror2.JPGHello good afternoon.
When I run my program (hello world) I get this error with the ISE free webpack license. Can somebody help me?
Attached two screenshots and the license used.
rshekhaw
Hi @dsej,
Glad to know the issue is resolved. Do you have further queries on this? If not, please close this thread by marking it as accepted solution.
Raj.
rshekhaw
Hi @dsej,
Please check this link, might be helpful:
https://www.xilinx.com/support/answers/40086.html
Also please share your license file and xinfo.txt.
Raj.
dsej
Hi @rshekhaw I don't know where is the accessories tab to extract xinfo system checker.
Is it in this menu? (Photo)
rshekhaw
Hi @dsej,
To generate xinfo file,
start menu start->Xilinx ISE design suite->Accessories->xinfo system checker.
It will generate xinfo.txt file.
Raj.
shameera
Hi @dsej,
At first, please point the generated web pack license file to xilinxd_license_file in XLCM.
Later make sure that you are targeting to the ISE web pack supported devices from the below link
https://www.xilinx.com/publications/matrix/Software_matrix.pdf
dsej
dsej
dsej
u4223374
Advisor
Advisor
@dsej
What device are you using?
Are you using any Xilinx IP cores in this project?
dsej
@u4223374 Hi, I'm going to work with a nexys 4 but I have not yet connected to the computer. I was just running a small program to verify that ISE works.
I'm not using IP cores.
dsej
There you have the xinfo file and my license, do you see something wrong? @rshekhaw
dsej
@shameera everything is correct, i use XC7A100T (artix 7)
rshekhaw
Hi @dsej,
I checked the files, they seems all correct.
Have you tried @shameera suggestion?
Raj
dsej
I have already solved it by placing my license file in a folder and pressing set.
However this did not work if I pressed load and looked for my license file ... I hope it is useful for someone.
thanks to everyone
rshekhaw
Hi @dsej,
Raj.
