EXCEPTION_ACCESS_VIOLATION in Vivado 2017.2
Updated OS today on a window 7 to window 10 (64bit)
When Window 7 , Vivado 2017.2 is normal working
but, After update window 10 , Vivado 2017.2 is abnormal working.
I attach the file ( *.log / *.dmp .... )
Check the File Please
Community Manager
Community Manager
Re: EXCEPTION_ACCESS_VIOLATION in Vivado 2017.2
Hi @skandra,
Is this failing during a certain job run or is this upon launching vivado in general?
A quick step to try is going into the vivado install and navigating to Xilinx\Vivado\2017.2\tps\win64 and running the xvcredist.exe and select repair. This would resolve a distributable conflict / error.
Ultimately you can also try re-installing Vivado to the new OS.
Thank you,
Devin
Community Manager
Community Manager
Hi @skandra,
Thank you,
Devin
Thanks for the reply.
Not resolved by the method offered.
So, I reinstalled the OS and solved this problem.
Community Manager
Community Manager
Hi @skandra,
That is good to hear. The most probable cause was due to the Microsoft Visual C++ Distributable compatibility issue. With the re-install of the OS the 2015 x64 and x86 bit versions most likely needed to be picked back up by Vivado.
Thank you,
Devin
