Newbie syedrnaqvi
Error Installing Xilinx_Vivado_SDK_2017.1_0415_1_Lin64.bin
I  trying to install the Webpack for Xilinx_Vivado_SDK_2017.1_0415_1_Lin64.bin and am getting the following error
The errors are shown in the attached ppt.
Re: Error Installing Xilinx_Vivado_SDK_2017.1_0415_1_Lin64.bin
Hello @syedrnaqvi ,
This error is due to the fact that the software can't be downloaded due to the fact that your Xilinx.com profile is possibly currently blocked by Xilinx Export Compliance checks.
Your actual location from where you are trying to download Xilinx software isn't the same what you have indicated in your Xilinx.com profile.
Due to this, your profile got blocked and that is the reason for this this 'badrequest' error message you are seeing.
If that is not the case, can you please try downloading the required software as a Single File Download (SFD), directly from the Xilinx Downloads Page rather than using the .bin file (i.e. via the webinstaller) and then see if you see an error or not. Here is the link to this:
https://www.xilinx.com/member/forms/download/xef.html?filename=Xilinx_Vivado_SDK_2017.1_0415_1.tar.gz
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Newbie syedrnaqvi
I am downloading this into a compute server in cloud. I am not sure why I am getting this error.
The link you send also did not work
Hello @syedrnaqvi ,
This confirms then that your profile is currently blocked by the Xilinx Export Compliance checks. That is the reason for this error.
Let me contact them and see if they can unblock it for you.
I will update you shortly on this.
Have a nice day.
Kind Regards,
Anatoli Curran,
Hello @syedrnaqvi ,
Your account is now unblocked, so you shouldn't see this error now. Please try installing this once again and it should now proceed further without the error you saw before.
If you have any questions for me, please let me know.
Kind Regards,
Anatoli Curran,
