dsej
Error map:258
Hi, I have an error with the free ISE pack license, it loads correctly but then it does not work. I use XC7A100T (artix 7).
Here I leave my xinfo file and license. (14.7 version)
shameera
Hi @dsej,
As mentioned by me in the other thread, please point the generated web pack license file to XILINXD_LICENSE_FILE in XLCM as still, you have not pointed to it.
shameera
Hi @dsej,
dsej
Thanks for answering @shameera, I have already solved it by placing my license file in a folder and pressing set.
However this did not work if I pressed load and looked for my license file ... I hope it is useful for someone.
