Error0001
I generated the VHDL code using the system generator, but I got the Error 0001. Would you please tell me the solution about this error.
Hi @NH999 ,
Can you confirm that you have a System edition license? can you see the Sysgen feature in VLM?
Please check if you are using the supported OS for Vivado 2020.1 and also, let me know the same.
UG973: https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug973-vivado-release-notes-install-license.pdf
Check your license CRC whether it is Okay to be used or not?
Please share the following files to check this issue:
  1. The complete license file(xilinx.lic).
  2. Run the below command from Vivado TCL console and share the generated xinfo.txt file, run pwd to know the location if this file.
report_environment -file xinfo.txt
Thanks & Regards,
Ansari Hunen
Don’t forget to reply, kudo, and accept as a solution.
Hi @NH999
You can refer to this forum post that addresses a similar issue. https://forums.xilinx.com/t5/Welcome-Join/Error-0001-Sysgen-license-checkout-failed/td-p/772610
Thank you for your reply.
I have checked the recommended link and executed the solutions, but I got same error 0001. would you please tell me another method to overcome this error as follows?
--------------------------------- Version Log ----------------------------------
Version Path
System Generator 2020.1 C:/Vivado/2020.1
Matlab 9.8.0.1359463 (R2020a) Update 1 C:\Program Files\MATLAB\R2020a
Vivado 2020.1 C:/Vivado/2020.1
Summary of Errors:
Error 0001: Sysgen license checkout failed.
XILINXD_LICENSE_FILE = C...
Block: Unspecified
Error 0001:
Reported by:
Unspecified
Details:
XILINXD_LICENSE_FILE = C:\Xilinx\Xilinx_license\Xilinx.lic;C:/Vivado/2020.1/data/sysgen/hwcosim_compiler/pp_ethernet
LM_LICENSE_FILE = C:\Xilinx\Xilinx_license\Xilinx.lic
License search path: C:\Users\neise\AppData\Roaming\XilinxLicense;C:\.Xilinx;C:\Xilinx\Xilinx_license\Xilinx.lic;C:\Vivado\2020.1\data\sysgen\hwcosim_compiler\pp_ethernet;C:\Xilinx\Xilinx_license\Xilinx.lic;C:\Vivado\2020.1\data\ipcore_licenses
Hi @NH999 ,
Thanks & Regards,
Ansari Hunen
