Evaluation License for ISE embedded
So I need to see if the ISE Embedded design suite will function as intended for a specific design. Which I think it will, but would prefer to test it first. I do not see it as an option for evaluation license anymore. I know I can get the ISE webpack, at the moment I have a license for the logic edition for ISE. I was wondering if there was anyway to use the IP Cores and the Embedded system kit that comes with the Vivado evaluation license with my logic edition license? Pretty much is there still a way for me to test out the embedded system kit on ISE for a 30 day trial.
Re: Evaluation License for ISE embedded
Hello @penderam,
Please note that Embedded Development Kit (EDK) includes both Xilinx Platform Studio (XPS) and the Software Development kit (SDK).
I can see you have a Logic edition license, however as you have already noticed, Logic Edition license doesn’t come with EDK (XPS and SDK) or SysGen features:
You can generate free webpack license which supports SDK and XPS (contains xps_tdp) for the smallest Zynq devices ONLY, i.e.: XC7z010 XC7Z020 and XC7Z030.
If you are using a different device then you need to purchase license.
For your question: “I was wondering if there was anyway to use the IP Cores and the Embedded system kit that comes with the Vivado evaluation license with my logic edition license? ….  is there still a way for me to test out the embedded system kit on ISE for a 30 day trial.
Please note that there is no longer an ISE 30-day evaluation license available.
If you target one of the smallest Zynq devices mentioned above, then ISE WebPACK can be used in this case.
Therefore, if you need to work with ISE tool as well as with the EDK tools, in addition to your Logic Edition license, you’d also need a separate (2nd) additional EDK standalone license.
I believe it is still possible to just buy an Embedded Development Kit, Software Development Kit and System Generator standalone licenses. However, you’d need to talk to your local Authorised distributor on this matter.
I hope the above is clear.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @penderam,
Kind Regards,
Anatoli Curran,
