Visitor hatlab_jpc
Failed in generating firmware " opt_design failed "
I'm using Keysight M3602A design environment to generate the firmware for our Keysight M3102A Digitizer (with Xilinx 7K410T FPGA). We followed the instruction in the document of M3602A, installed Vivado 2015.2 and got the web pack license. However, the generating process always fails at 36% with an Error says "ERROR: [Common 17-345] A valid license was not found for feature 'Implementation' and/or device 'xc7k410t-ffg676'."
The document from Keysight only says we need the web pack license and doesn't mention any other licenses we need. I'm wondering is this the problem of the missing license or our setting...
Attached is the screenshot and log file of the failed process. Please help.
Thank you.
Sincerely,
Chao Zhou
Teacher drjohnsmith
Re: Failed in generating firmware " opt_design failed "
check is that version of the chip supported in that version of vivado web pack ?
Visitor hatlab_jpc
yep, we have already checked
Hi @hatlab_jpc
Try installing Vivado 2015.2 update
Bhushan
Bhushan
Hello @hatlab_jpc,
Please note that Kintex 7 7k410t part isn't a webpack part, so a webpack license won't be valid here. A full license is required here or a device locked license locked to 'xc7k410t-ffg676', in order to overcome this issue.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
