Floating License Vivado 2017.4
We use Vivado 2017.4 and we have one floating license.
Vivado 2017.4 is on three different computers and these computers get the license from license server.
If one of these computers is doing synthesis can other computer do implementation or vice/versa?
At the moment we can not do any operation of synthesize or implementation while other computer is doing one of them ( synthesize or implementation) ? Is this normal behavior of one floating license?
Mustafa
Re: Floating License Vivado 2017.4
Hello @mustafa.su,
Once the user kicks in any of the runs (Synthesis or Implementation) on 1 PC, the entire license will get occupied for the entire duration of the run, even when only Synthesis feature is required. If you open VLM, here you can see seats in use for Vivado_System_Edition =1 and also across e.g. Synthesis =1.
Therefore 1 seated license can only be used on a particular machine. Once the license checked out by a user, this particular user can then simultaneously run multiple runs on this PC (on this particular machine only).
However, for 3 user to simultaneously run 3 different runs on 3 different machines, you'd need a license with minimum seats of 3 (i.e. this is equivalent to 3 separate license files). Therefore, the behavior you are seeing right now is the expected behavior.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hi @mustafa.su,
Yes, you can do synthesis/impl. simultaneously on three machines if you have three seats of synthesis and implementation feature in your license file (.lic). You can see it in your Vivado license file.
This is not normal behavior. If you have more users then your seats, some users will face errors related to license file missing.
hemangd
If your query has been answered, you can close this thread by making it as accepted solution.
hemangd
Hi @hemangd
Attachment shows our licenses as shown in Vivado License Manager.
As in the picture we have for example:
1 seat implementation
1 seat synthesize
1 seat SDK
1 seat Vivado_System_Edition
For example we have 1 seat for implementation and 1 seat for synthesize as above.
When implementation is used "seats used" flag of implementation goes 1
but "seats used" flag of synthesize is still 0.
So i thought that someone will be able to do synthesize while other person is doing implementation or vice/versa?
Hi @mustafa.su,
Have you tried at your end? Is it working?
hemangd
hemangd
Hi @hemangd
Yes we tried it but it is not working.
We have always license error.
Presently we started to do much work on FPGA design and this license error slows down us.
If it is possible to do synthesize and implementation at the same time it will be enough for now.
We will handle the impossibility of simultaneous synthesize or simultaneous implementation
by doing them at different moments.
Do you have any ides why we have license error?
Hi @mustafa.su,
Please provide your floating license file (.lic), vivado environment file (run "report_environment -file <filepath>/env.txt") and debug.log (from server lmgrd -c Xilinx.lic -l debug.log This will generate the debug.log in the same folder) file to evaluate.
hemangd
hemangd
Hello @mustafa.su,
Kind Regards,
Anatoli Curran,
Hi @anatoli,
Thanks for the explanation. I got the situaiton.
Mustafa
