For Linux operating systems, licensing environment variables cannot be set using the Vivado License Manager(VLM) how to set this
The following workflow is only applicable for Windows.For Linux operating systems, licensing environment variables cannot be set using the Vivado License Manager(VLM). The environment variable fields are read only, so they are grayed out and there are no Set buttons. Theenvironment variable must be set using the appropriate OS shell and commands
what are the commands for ubuntu16.04
Re: For Linux operating systems, licensing environment variables cannot be set using the Vivado License Manager(VLM) how to set this
Hello @gsm2019 ,
Please do a Google search and you should find the way of setting this up on Ubuntu, as to me, this is depends on what shell you are using.
Here is an example link that i've just found: https://askubuntu.com/questions/58814/how-do-i-add-environment-variables
So, if you are in csh/tcsh, you'd need to use 'setenv' instead of 'export' (which is used in sh/bash shell)
To check what shell you are in, you can run this command:
echo $0
Then, based on the shell you are in, please set your environment variable as indicated in the link above.
Hope this helps.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @gsm2019 ,
On Ubuntu, you can use this command, e.g.:
export XILINXD_LICENSE_FILE=/opt/licenses:2100@server_name
In the above example command i've shown /opt/licenses as the folder where you'd have your Xilinx related Node-Locked licenses located, and '2100@server_name' - is your pointer to the floating license server, if you have one in place.
All the locations and servers must be separated by colons (:) (on Linux) as shown above. On Windows you'd need to use semicolons (;).
Hope this helps.
Kind Regards,
Anatoli Curran,
sameer-gsm@sameergsm-desktop:~$ export XILINXD_LICENSE_FILE=/home/sameer-gsm/.Xilinx/licenses:2100@LicServer
sameer-gsm@sameergsm-desktop:~$ echo XILINXD_LICENSE_FILE
   THIS IS WHAT I have done and but no showing of any license in view lisense staus
Hello @gsm2019 ,
echo $0
Hope this helps.
Hope this helps.
Kind Regards,
Anatoli Curran,
