Free Licensing Problem.
Accepted Solution Solved
Accepted Solution
I am electronics engineering student.
I downloaded ISE 14.7.
The download and installation went successfully, the XLCM directs me to this page for a license to download:
https://xilinx.entitlenow.com/AcrossUser/main.gsp?licenseType=2&product=0451108&tab=&uuid = &
But the page is blank.
What is wrong? What should I do to download a free license?
Re: Free Licensing Problem.
1. Clear your browser cache and try again.
2. If the above step doesn't help, fill the following form to contact customer service team: http://www.xilinx.com/askx/customer_service_form.htm
All Replies
Kudos: 799
Solutions: 1,019
Go to www.xilinx.com/getlicense to generate free webpack license.
Deepika.
Deepika.
Kudos: 147
Solutions: 130
Go to www.xilinx.com --> login into your account --> support-->get license file. select the particular tool & download the license file.
save it in your system check page 31 http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_5/irn.pdf
Harry
the process you are following is correct. can you please try in other browsers?
-Pratham
Thanks to all respondents.
I tried both on the windows explorer and the chrome browser, to get directly to xilinx/getlisences but again and again i am got to same page witout ability to download any file.
can you send me lisence file at the mile?
Sorry for the spelling mistakes.
I'll be glad if you send me a license file by email.
Thank You
[ Edited ]
Use internet explorer and follow the steps mentioned by Harry in his post.
While the webpage (Product Licensing Site) is loading, you will get a pop-up as below:
Select "No" in the pop-up, then the webpage will be loaded.
I hope it helps.
I followed the instructions of Harry, still did not load the license file.
Screenshot attached in word file.
It worked.
Deleting the cache solved the problem.
Thank you very much.
