Visitor acleone
Guide for ISE 12.1 on 64-bit Ubuntu 10.04
Installation
  1. Save the downloaded 12.1 archive anywhere (it's just the setup/install files)
  2. Extract the archive (right click -> Extract here)
  3. Open a terminal (Ctrl + Alt + t), navigate to the folder, and run xsetup as root:
    cd Xilinx_ISE_DS_Lin_12.1_M.53d.0.4/
    sudo ./xsetup
  4. Follow the instructions in the setup wizard that pops up, and use the default install location
run_ise.sh Script and Adding the Launcher to the Applications Menu
  1. Create a new file in your home folder, run_ise.sh, containing:
    #!/bin/bash
    ISE_DS_DIR=/opt/Xilinx/12.1/ISE_DS
    cd "$ISE_DS_DIR"
    source "$ISE_DS_DIR"/settings64.sh
    export LANG=''  # reset locale to English to fix decimal/comma seperation
    "$ISE_DS_DIR"/ISE/bin/lin64/ise
  2. Make the run_ise.sh script executable:
    chmod u+x run_ise.sh
  3. Create an applications menu launcher for the run_ise.sh script:
    1. Right click "Applications" on the top bar and then "Edit Menus"
    2. Click the Programming Category on the Left and then "New Item" on the right
    3. Change Type: to "Application in Terminal", Name: Xilinx ISE 12.1, Command: point to the run_ise.sh script
64-bit Fix for PlanAhead
  1. By default, PlanAhead will try to use 32-bit executables.
    1. Open /opt/Xilinx/12.1/ISE_DS/PlanAhead/bin/rdiArgs.sh in gedit as root:
      sudo gedit /opt/Xilinx/12.1/ISE_DS/PlanAhead/bin/rdiArgs.sh
    2. Change lines 7-11 from
      # Default to 32bit platform options
      RDI_PLATFORM=lnx32
      RDI_JAVA_PLATFORM=i386
      to
      # Default to 64bit platform options
      RDI_PLATFORM=lnx64
      RDI_JAVA_PLATFORM=amd64
Change PDF Viewer to evince
  1. Create a symbolic link from /usr/bin/evince to /usr/bin/acroread:
    sudo ln -s /usr/bin/evince /usr/bin/acroread
Re: Guide for ISE 12.1 on 64-bit Ubuntu 10.04
Instead of creating the acroread script, you can just make a softlink:
(it would be a better idea to create the link on /usr/local/bin instead of /usr/bin, but I don't know if Xilinx runs `/usr/bin/acroread document.pdf` or just `acroread document.pdf`)
Visitor acleone
Good catch.  A symbolic link is much cleaner.
I've just noticed that XPS 12.1 BSB wizard (and maybe some other products of the Xilinx suite) doesn't work if your system uses a locale that uses commas instead of periods as decimal separator ("3,14" instead of "3.14"). If this is your case, you may want to add this somewhere on your .sh script:
export LANG=''
This removes the locale for the program, and makes it use the default one (English, decimal period).
Visitor teun.compen
I installed ISE 12.1 on a Centos 5.4 PC, but how do I start it? With 11.5 I could start XPS or ISE by executing 'xps' or 'ise' on the commandline after running the scripts. For some reason this won't work with 12.1. What am I doing wrong?
Did you source the settings script within the Xilinx directory?  Should be in the same level as ISE, EDK, PlanAhead...
Visitor teun.compen
When I run the scripts I am able to run ISE. For some reason I cannot run XPS. This is what I did:
[teun@bdaz1100 ~]$ cd /opt/Xilinx/12.1/ISE_DS/
[teun@bdaz1100 ISE_DS]$ source settings32.sh
[teun@bdaz1100 ISE_DS]$ cd PlanAhead/
[teun@bdaz1100 PlanAhead]$ source settings32.sh
[teun@bdaz1100 PlanAhead]$ cd ../ISE/
[teun@bdaz1100 ISE]$ source settings32.sh
[teun@bdaz1100 ISE]$ cd ../EDK/
[teun@bdaz1100 EDK]$ source settings32.sh
[teun@bdaz1100 EDK]$ cd bin/lin/
[teun@bdaz1100 lin]$ ./xps
Visitor reconfig15
And how should one start Coregen in Ubuntu? On windows you can simply go to the program folder in the start menu and you can start it but I haven't  yet found any executable file named "coregen" in the installation directory in Ubuntu.
Visitor reconfig15
@teun, try running the settings.sh file in the "common" directory as well. It may help.
Visitor teun.compen
Yesterday I installed 12.1 on a 64bit Red Hat Enterprise Linux PC. After running the settings64.sh script I could start ISE or XPS just like I could start it on my own pc with 11.5. Just type 'xps' or 'ise' on the command line of the terminal and the tool starts. Running settings32.sh script makes no difference, it just works as it should.
I reinstalled 12.1 on my own pc (Centos 5.4) but it won't make any difference. For some reason I can not start XPS or ISE. Could the installation of 11.5 have any influence? 11.5 is not installed on the Red Hat PC.
Thanks, that's helpful. I'm still having a problem with Chipscope 12.1 on Ubuntu 10.04 64-bit though. Is there a chance it's having a 32-bit vs. 64-bit executable issue as well? When I double click Analyze Design Using Chipscope from ISE I get the following message:
Running analyzer...
Command Line: -cwd "/fpga/VHDLRef/mig_v3_4/example_design/par" analyzer -intstyle ise -project "/fpga/VHDLRef/mig_v3_4/example_design/par/example_top.cpj" -bit_default "/fpga/VHDLRef/mig_v3_4/example_design/par/example_top.bit"
Process "Analyze Design Using Chipscope" launched successfully
Running analyzer...Command Line: -cwd "/fpga/VHDLRef/mig_v3_4/example_design/par" analyzer -intstyle ise -project "/fpga/VHDLRef/mig_v3_4/example_design/par/example_top.cpj" -bit_default "/fpga/VHDLRef/mig_v3_4/example_design/par/example_top.bit"Process "Analyze Design Using Chipscope" launched successfully
Of course, nothing actually opens. On Red Hat RHEL 5 64-bit this works.
Also, is there any way to prevent the Terminal window from appearing/lingering after ISE's done launching, or have it not show all-together? Thanks.
Visitor sonson170
Hi all
I made all procedure mentioned by acleone, but it dosenot work.
Here is my script as mentioned in this post:
sudo ./xsetup
 sudo: ./xsetup: command not found
Then I tried:
sudo bash xsetup
 xsetup: line 25: ./bin/lin/xsetup: Permission denied
And also tried:
 sudo dash xsetup
 xsetup: 32: ./bin/lin/xsetup: Permission denied
I'm using Ubuntu 10.04 LTS on 32-bit machine.
can anyone help me?
Are you doing this from a section of your drive where you have write permission? The Xilinx setup software needs to be able to write to wherever it's being launch from. This makes for a hard time installing from the CD directly :) If that's what you were trying to do, copy the contents of the CD/DVD to your hard drive first.
Visitor sonson170
Thank you
Xilinx_ISE_DS_Lin_12.1_M.53d.0.4.tar
Newbie ilghiz
I recently installed ISE Web eddition at my Ubuntu 10.04 on amd64 platform, register my web licence, followed by instructions on this topic to generate run_ise and start the ISE. It is starteb, but it produce:
./run_ise: line 10:  5675 Segmentation fault      "$ISE_DS_DIR"/ISE/bin/lin64/ise
any time when I try to create new project. I am trying to allocate new dir in my home like: ~/FPGA/first, set everything to Spartan 3a DSP, and when I press the button "Finish" it waits... waits a lot, and when I press this button again or any other buttons, it crashes.
Please, advice me what to do!
Sincerely,
Ilghiz
Newbie ilghiz
At the concole it writes:
(x) ERROR: unknown project version :.
(x) ERROR: project cannot be migrated.
Visitor jurban15
Thanks a lot for this tip. The instructions work in Linux Mint 9 Isadora as well, except for a small change to step 3. To create a shortcut, drag run_ise.sh to the Linux Mint icon in the main toolbar.
Just found out that
export LC_NUMERIC=C
also works for the decimal comma bug, and doesn't cause child processes (evince, firefox...) use English when the locale is set to another language.
I'm working on a post-installation script to automate everything (creation of wrapper script, bash completion, cable drivers, installation of dependencies, symbolic links...). Attached to this message.
I haven't tested it, but it may work on Ubuntu and maybe Debian. It's more like a list of steps I've followed myself. I recommend to check it before running it, just in case.
By the way, is editing PlanAhead/bin/rdiArgs.sh the only way around for the 64-bit problem? That script is supposed to work for 64-bit architectures if you call it with the -m64 command line option. No clue where's that script called from, though.
EDIT: Attachment updated; there was a bad mistake on line 45.
As of Xilinx 14.1, this bug seems to persist.
Newbie ljubo
hello!
I've set the right path but can't run sudo ./xsetup. It says sudo: ./xsetup: command not found.
I've seen previous solution by sonson, but I've downloaded tar file and extracted it on desktop.
Do you have any idea what's going on?
Thanks in forward.
