Have a original vivado .lic file. Still license error occurs
I have a original vivado license file which i got the with the Artix 7 FPGA board. After installing the license, i can see that the Expiration date is set to "Permanent" in the license manager. But still i get this error while running the simulation or synthesis.
ERROR: [Simtcl 6-50] Simulation engine failed to start: A valid license was not found for simulation. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system.
Thanks for the help in advance.
Hi @sandy_1022,
Go for Vivado Webpack license.
Arpan
Arpan
Hi @arpansur
Thanks a lot for all your help. I was finally able to simulate and synthesize an AND gate code on vivado 2015.4 using a webpack license.
Now is this webpack license device specific? Because i have to finally implement my code using the device that i have mentioned earlier(XC7a200tfbg676) and get the output on FPGA. So is it ok if i just specify the part at the start of a New project and go on?
Sandeep
Hi @sandy_1022,
You can only use the webpack devices as mentioned in my previous replies.
As your issue is resolved please close this thread by marking "Accept as solution" to the answer that addressed your query.
Also give kudos to the answers that you think helpful.
Arpan
Arpan
@arpansur
@ashishd
@tusharvi
@syedz
@nupurs
Oh yes sure! definitely!
I was finally able to install a webpack
Thanks to all for your contributions.
Sandy
HI Sandy,
We are glad we could help you with the issue!
Feel free to open a new thread if you face any other issues.
Tushar.
