williamlu97
Having trouble connecting to Virtex-7 FPGA
I'm currently using an eval board from Analog Devices, the ADS7-V2EBZ eval board.  It is based off the Xilinx Virtex-7 XC7VX330T-3FFG1157E FPGA.  I downloaded Vivado and when i'm creating a project i can't find the exact part for this board.  When i choose one that's similar I'm unable to get past the Code Synthesis step and it give tells me that there's something wrong with my license.  Do i need to buy a specific license to use with this board?
Also how do i get past the Bitstream generation step?  When i choose a different part just to test my code i get an error on the bitstream generation part where it tells me i haven't defined the I/O ports.  Is there a way to get past this step?
u4223374
Advisor
Advisor
You will need a Vivado Design Edition license; the free WebPack license does not support the Virtex chips.
If bitstream generation is complaining that you haven't defined your I/O ports, the obvious question is whether you have actually defined your I/O ports. Have you?
williamlu97
I have not defined my I/O ports, i'm not sure how to define ports.  Are there any resources for beginner FPGA coders that i can look at?
panantra
Hi @williamlu97 :
You must have a license to use this device.
Vivado WebPACK Tool does not support Virtex-7 FPGA. That's why you are getting a license error in code synthesis step. You will need Vivado Design Suite Editions (latest are 2018.2 or 2018.3) that support Virtex-7 devices.
You will only be able to use below devices with Webpack Edition 2018.3:
You can check this link for reference :
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0013-vivado-installation-and-licensing-hub.html
You can refer to Vivado Design Suite Tutorial 1.Using Constraints (UG945) and 2.Design Flows Overview (UG888) to learn about complete Vivado Project flow untill Bitstream generation.
1. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug945-vivado-using-constraints-tutorial.pdf
2. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug888-vivado-design-flows-overview-tutorial.pdf
Priyanka
If you find this information useful, please mark it "accept as solution"
