Observer yizhao.cheng
Help for vivado bit file generate license problem
When I use vivado 2019.1 generate bitstream with trial license, I meet a problem like below:
Is trial license do not support bit stream generation?, if not, how can I solve the problem?
Re: Help for vivado bit file generate license problem
It is license problem, after regenerate trial license, the problem is solved.
