cramcram
How do you set XILINXD_LICENSE_FILE when using Fedora linux Mate (Gnome 2) launcher?
We use a floating license server here at work.  I added the export definition for XILINXD_LICENSE_FILE and the settings64.sh script to my .bashrc.  If I run vivado from a terminal session everything works.  If I use the launcher setup by the Vivado installer the XILINXD_LICENSE_FILE env variable doesn't get set.
Where/what is the proper way to set this up so that I can just double-click the launcher icon to start Vivado?
Marc
vuppala
Hi @cramcram
Open Vivado License Manager through Vivado GUI (i.e., Vivado launcher --> Vivado GUI --> Help --> Manage License) and check for XILINXD_LICENSE_FILE is set?
If it is not set, set this environmental variable using export command with root privileges.
Vinay
cramcram
Thanks for the reply Vinay.
I'm surprised I didn't think of the easiest solution right off the bat.  I simply created a shell script that sets the licensing variable and executes the settings64.sh script then starts vivado.  Then I changed the launcher icon to run that script instead of directly starting Vivado.
Thanks again,
Marc
