xil_tour
How to setup SDx for Amazon F1 ?
I have a working installation of SDx.
I would like to use it to develop an Amazon F1 application, so I have some questions:
1- Which PCIe card(s) are available in F1 ?
2- What are the files needed for each of these cards ?
3- How do I install those files in SDx ?
Any help will be appreciated !
anatoli
Hello @xil_tour,
Please post this topic on the Amazon Discussion Forums using this link:
https://forums.aws.amazon.com/forum.jspa?forumID=243&start=0
Thanks in advance and have a nice day.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
xil_tour
xil_tour
Here's a copy of my AWS forum post where I detail the solution:
As the https://github.com/aws/aws-fpga.git stuff simply and amazingly _doesn't work as is_, here's the procedure to make it run smoothly:
git clone https://github.com/aws/aws-fpga.git
cd aws-fpga/
vim ./sdk/userspace/fpga_libs/fpga_pci/fpga_pci.c
Line 214, change this:
char wc_suffix[3] = "\0";
        if (map->resource_burstable[bar_id] && write_combining) {
                strncpy(wc_suffix, "_wc", sizeof(wc_suffix));
Into this:
 char wc_suffix[4] = "\0\0\0\0";
                strncpy(wc_suffix, "_wc", 4);
Next:
vim ./SDAccel/tools/awssak2/Makefile
Line 53, add -lpthread like this:
LDFLAGS += -L$(AWS_FPGA_MGMTLIB_DIR) -lpthread
Next:
vim ./sdk/linux_kernel_drivers/xocl/xocl_bo.c
Lines 36 and 54, change
#if (LINUX_VERSION_CODE >= KERNEL_VERSION(4, 13, 0) ||    \
    (defined(RHEL_RELEASE_CODE) && \
    RHEL_RELEASE_CODE >=RHEL_RELEASE_VERSION(7,5)))
into
#if (LINUX_VERSION_CODE >= KERNEL_VERSION(4, 13, 0))
Next:
vim ./sdk/linux_kernel_drivers/xocl/xocl_drv.c
Do the same previous change at lines 315 and 587
Run
source sdaccel_setup.sh
You can safely ignore the
WARNING:  ocl-icd not installed - please run: sudo yum install ocl-icd
warnings, it seems the script was made to be compatible only with redhat/centos/stupiddistro/fedora alikes.
I has to be noted that SDx/SDAccel op (on premise) doesn't come with any platform, the the next move is to copy:
./SDAccel/aws_platform/xilinx_aws-vu9p-f1_dynamic_5_0/
into (create the platforms folder if not present):
./Xilinx/SDx/2017.4.op/platforms/
Hope this will help.
sinatv52
NOT working with 2018.3 version
