How to solve Xilinx Licence Manager for Error Map:258/ Security :9C
Hello, everyone.
I am facing the following ERROR ISE14.7 windows10 .
ERROR:Security:9c - No 'ISE' nor 'WebPack' feature version 2013.10 was available
ERROR:Map:258 - A problem was encountered attempting to get the license for this
   architecture.
I have checked some similar posts already.
But I do not yet find how to solve these error,Sorry.
That error might be  caused by License.
attached XLCM screen copy and Error report.
I have installed ISE twice or more.
Before I have completed Map process.
But I have a trouble USB driver to writer to Target EEPROM,
so I re-install ISE 14.7 and get license again.
(USB Driver problem havs been solved by re-install.)
But after this, I have a Map process Error now.
Could you help how to solve this problem?
Started : "Map".
Running map...
Command Line: map -intstyle ise -p xc6slx25-csg324-2 -w -logic_opt off -ol high -t 1 -xt 0 -register_duplication off -r 4 -global_opt off -mt off -ir off -pr off -u -lc off -power off -o TOP_PXY001_Starter_map.ncd TOP_PXY001_Starter.ngd TOP_PXY001_Starter.pcf
Using target part "6slx25csg324-2".
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
INFO:Security:54 - 'xc6slx25' is a WebPack part.
INFO:Security:60 - The XILINXD_LICENSE_FILE environment variable is set to
'XILINXD_LICENSE_FILE  =C:\.Xilinx'.
INFO:Security:62 - The LM_LICENSE_FILE environment variable is set to
INFO:Security:68 - For more information or for assistance in obtaining
 a license, please run the Xilinx License Configuration Manager
       (xlcm or "Manage Xilinx Licenses".)
INFO:Security:68a - user is T.Shimokawa, on host PC1803004.
for part 'xc6slx25'.
No such feature exists.
Feature:       WebPack
License path:  XILINXD_LICENSE_FILE  =C:\.Xilinx;C:/.Xilinx\Xilinx
(1).lic;C:/.Xilinx\Xilinx.lic;C:\Xilinx\nt64\14.7\ISE_DS\ISE\/coregen/core_licen
ses\Xilinx.lic;C:\Xilinx\nt64\14.7\ISE_DS\ISE\/coregen/core_licenses\XilinxFree.
lic;C:\Xilinx\nt64\14.7\ISE_DS\EDK/data/core_licenses\Xilinx.lic;
FLEXnet Licensing error:-5,357
For further information, refer to the FLEXnet Licensing documentation,
available at "xxxxxxxx such feature exists.
Feature:       ISE
available at "xxxxxxxxxxxx".
   architecture.
Design Summary
Number of errors   :   1
Number of warnings :   0
Process "Map" failed
Re: How to solve Xilinx Licence Manager for Error Map:258/ Security :9C
Hello @t-shimokawa ,
You've installed Vivado WebPACK license which won't be valid for ISE WebPACK.
You'd need an ISE license file to solve this issue.
If you don't have one, you can obtain a free version of this license from www.xilinx.com/getlicenses page.
FYI - now a days, all of our customers can obtain an ISE Embedded Edition license free of charge. All they need to do is to log in into www.xilinx.com/getlicenses and they should see this FULL ISE Embedded Edition license in the entitlement list. If you don’t see this, please let me know.
Installing and using this license will allow you to overcome this licensing issue then.
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hope this helps.
Kind Regards,
Anatoli Curran,
Anatoli, Thanks a lot.
Are there any difference ISE webpack license and Embedded Edition license?
Before I could find out ISE webpack license in the entitlement list .
But as you said, now a day I can not see it any more. I can only find out Embedded Edition license.
Can i have same result as before by using Embedded Edition license?
Dear,All
I have gotten ISE Embedded Edition license
Then Map process has completed.
My problem has solved.
Thank .
Thanks a lot for letting us know. Glad your issue is now resolved.
As your issue is resolved and if there are no further questions, can you please mark a response as Accepted Solution (more info on this can be found here: https://forums.xilinx.com/t5/help/faqpage/faq-category-id/solutions#solutions), so that the topic can be completed then?  We appreciate your help.
Have a nice day.
Kind Regards,
Anatoli Curran,
