I can't register my floating license in VLM 2017.2
Hello
I have problem that I can't register my floating license in VLM 2017.2.
When I try to copy license for cetificated license, I got this messages as shown below.
Even though I don't have D:\ in my Local PC, it would like to be copied in D:\
Can I change my homedrive from D:\ to C:\ ?
Please let me know how to solve this problem..
回复: I can't register my floating license in VLM 2017.2
"Copy License" is the installation method for node-locked license. For floating license, you need to start the license server and then set XILINXD_LICENSE_FILE to point to the server.
For more details, please refer to UG973:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_2/ug973-vivado-release-notes-install-license.pdf
pg57, section "Serving Certificate-Based Floating Licenses".
