I get "ERROR: This installation is not supported on 32 bit platforms." on a 64 bit platform
Debian Jessie 64 bit system. When running the Linux installer ./Xilinx_Vivado_SDK_2015.1_0428_1_Lin64.bin it prints Even after removing i386 support from multiarch, including every 32 bit package, the installer greets me with this error.
Re: I get "ERROR: This installation is not supported on 32 bit platforms." on a 64 bit platform
Apparently the xsetup script uses "uname -i" which returns "unknown" on my Arch linux installation.
But if you know that you have an x86_64 system, you can simply comment out the check in the xsetup file, installation goes file and it seems also that vivado & vivado hls work fine that way.
[ Edited ]
Debian is unsupported OS and we have not tested Vivado on Debian.
Try using supported OS.
Microsoft Windows Support
• Windows 7 and 7 SP1 Professional (64-bit), English/Japanese.
• Windows 8.1 Professional (64-bit), English/Japanese.
• Vivado® Lab Edition is the only Xilinx toolset that supports Windows 7 SP1
Professional, 32-bit Operating System. Lab Edition also supports the 64-bit systems.
Linux Support
• Red Hat Enterprise Workstation 7.0 (64-bit)
• Red Hat Enterprise Workstation 6.4-6.6 (64-bit)
• SUSE Linux Enterprise 12.0 (64-bit)
• Cent OS 7.0 (64-bit)
• Ubuntu Linux 14.04 LTS (64-bit)
• Vivado Lab Edition is the only Xilinx toolset that supports the Red Hat Enterprise
Workstation
Thanks,Vijay
This might be an unsupported OS, but uname -m is the right command to check the architecture ;).
Best Regards,
Stephan
Yap!
I am running Arch Linux too. Solved the problem by:
1\ starting the installer with the --confirm parameter , path to the xsetup file got displayed
2\ finding and modifying the xsetup file (uname -m).
3\ confirmed the execution of xsetup in the installer shell.
Worked fine!
Although it's possible to install Vivado 2015.1 on 32-bit OS, it's not recommended to use in that way
1. No test has been made on these unsupported OS by Xilinx
2. Limit on physical memory for 32-bit OS hinders the performance.
Nobody said that someone installs Vivado 2015.1 on 32-bit platform. However, the usage of 'uname -i' in xsetup is wrong and should be replaced by 'uname -m'. The first one returns the hardware platform (e.g. GenuineIntel, AuthenticAMD, ...) and the latter one returns the machine hardware name (e.g. i386, i686, x86_64, ...).
Visitor ldp
tud_hartmann is right, it is correct solution.
I had the same issue to install Vivado or to install SDK separatly. A colleague from software staff found a solution. In Debians, their is an uname working well (at least for "-i" otpion):
 $ /usr/lib/klibc/bin/uname -i
Solution :
 $ sudo dpkg-divert --add --rename --divert /bin/uname.orig /bin/uname
 $ sudo ln -s /usr/lib/klibc/bin/uname /bin/uname
To go back :
$ sudo dpkg-divert --rename --remove /bin/uname
sources: https://bugs.launchpad.net/ubuntu/+source/coreutils/+bug/470550
I have downloaded the Linux 64 bit installer (.bin). I am running on a supported 64 bit Linux (Ubuntu 14.04). I am getting this same error. Is there a workaround? I saw mention of a command line option, but I haven't found documentation for that. (Not really sure where to look.) I am running a VMware Ubuntu 14.04.3 (Trusty Tahr).
