ISE 13.1 errors at VISTA 64bit
I install ISE 13.1 at VISTA 64bit. Sometimes, when I create a new project, and add files I get an error: "_pn.exe has stopped working" , and the the ISE is closed - I can not work with the problem. What is the problem? How can I fix it?
Can ISE 13.1 version works on VISTA?
Instructor
Instructor
Re: ISE 13.1 errors at VISTA 64bit
ISE 13.1 is a new release, and there have been several reports of crashes and other problems.
Suggest you open a webcase to report your problem (and create a bug report submission).  Then download and install ISE 12.4 and see if the 12.4 release works better for you.
Some more suggestions:
  • Keep current with Windows updates
  • Try 32-bit GUI shell instead of 64-bit shell
Good luck!
-- Bob Elkind
SIGNATURE:
Summary:
