Visitor ikpdarmstadt
ISE 13.1 on kubuntu 11.04
I've installed an ISE 13.1 on a new kubuntu 11.04 (32 bit). The installation went fine, and ISE starts, but if I try to compile a project (through a makefile) the compilation stops with an error. The procedure is as follows:
.  /opt/Xilinx/13.1/ISE_DS/settings32.sh
make
gcc sourcecode.c -options
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl_c.so.2)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libppl_c.so.2)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /usr/lib/libppl_c.so.2)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.14' not found (required by /usr/lib/libppl_c.so.7)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libppl_c.so.7)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /usr/lib/libppl_c.so.7)
/usr/lib/i386-linux-gnu/gcc/i686-linux-gnu/4.5.2/cc1: /opt/Xilinx/13.1/ISE_DS/common/lib/lin/libstdc++.so.6: version `GLIBCXX_3.4.11' not found (required by /usr/lib/libppl_c.so.4)
These errors won't appear, if one don't source the settings32.sh, but then the coregen breaks with an error, which may be caused by the inapprobiate libraries.
The same project compiled fine on a kubuntu 10.10(64bit), so I wonder, if there might be an issue with the new ubuntu version and ISE?
Has somebody else tried something similar and succeeded? Is this problem known?
Thanks for all answers
Visitor jo21053
Re: ISE 13.1 on kubuntu 11.04
Update to my fix above:
I started having libstdc++ issues again when running some very particular features. While tracking the source of the problems down I discovered that there are more stdc libraries hidden in other folders. Also, it turns out linking is unnecessary. If the libraries are moved or renamed to soming the Xilinx programs are not expecting they'll give up and search for your system libraries and locate them just fine. Here is the revised solution with new directories and no links:
cd /opt/Xilinx/13.1/ISE_DS/ISE/lib/lin/
mkdir orig && mv libstdc++* orig
cd /opt/Xilinx/13.1/ISE_DS/ISE/lib/lin64/
cd /opt/Xilinx/13.1/ISE_DS/common/lib/lin/
cd /opt/Xilinx/13.1/ISE_DS/common/lib/lin64/
Teacher drjohnsmith
In know a lot of people who would be very happy if xilinx officialy supported ubunto,
but till then,
good luck, and post if you get it working,
Voyager
Voyager
Hi Kubuntuer,
  It seems ISE adds its library path in from of the system libraries in the $LD_LIBRARY_PATH environment variable, like:
/opt/xilinx_13.1/ISE_DS/common/lib/lin64:/opt/xilinx_13.1/ISE_DS/ISE/sysgen/lib:/opt/xilinx_13.1/ISE_DS/ISE/lib/lin64:/opt/xilinx_13.1/ISE_DS/ISE/smartmodel/lin64/installed_lin64/lib:/opt/xilinx_13.1/ISE_DS/EDK/lib/lin64:/opt/xilinx_13.1/ISE_DS/common/lib/lin64:/opt/xilinx_13.1/ISE_DS/ISE/sysgen/lib:/opt/xilinx_13.1/ISE_DS/ISE/lib/lin64:/opt/xilinx_13.1/ISE_DS/ISE/smartmodel/lin64/installed_lin64/lib:/opt/xilinx_13.1/ISE_DS/EDK/lib/lin64
 and this possibly affects the gcc compiler by looking into ISE paths before the system paths. You may have to hide this variable before running gcc and then bring it back after gcc is done. Something like:
LD_LIBRARY_PATH_SAVE=$LD_LIBRARY_PATH
export LD_LIBRARY_PATH=
gcc ...
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH_SAVE
  I haven't tried this and you may have to play around with it. Please post if you get it working.
Good luck,
-Pat
https://tuxengineering.com
Thanks for the suggestion. After some try and error I've managed to include this into my makefile. But unfortunately this hasn't solved my problem with the coregen. It seems, that coregen won't work correctly under natty.
I will fall back to maverick, for now.
Thanks to all, who replied.
Visitor jo21053
Is there any particular reason you're running a 32bit ISE and a 32bit kubuntu?
Currently I'm successfully running 64bit ISE 13.1 on 64bit Ubuntu Natty 11.04. Below is a solution that may still work to fix those nasty libstdc++ errors, even on 32bit software.
There was one trick I needed to get rid of similar errors like: ERROR: libstdc++.so.6: version `GLIBCXX_3.4.14' not found
First change to the appropriate ISE library directory. Move the original libstdc++.so.6 that's giving us problems to a safe backup location. Then create a link to the host system's libstdc++. Depending on whether your ISE and linux is 32 or 64bits the directories will be slightly different, lin vs lin64... etc. The following is the exact set of commands which fixed mine. I was surprised that in my 64bit Ubuntu the only stdc++ was in lib32 so make sure you check it's location before linking.
mv libstdc++.so.6 libstdc++.so.6.orig
ln -s /usr/lib32/libstdc++.so.6 libstdc++.so.6
Newbie waldek85
Thanks a lot. It helped me to fix it up in OpenSUSE 11.4. This is a good way to resolve that problem.
Visitor jo21053
Newbie grant.271
Thanks for posting this. The "no links" solution worked perfectly for me in Ubuntu 11.04 x86_64.
Newbie cgreco
Not surprising, the "no links" method works for ISE 13.2 on ubuntu 11.04 x86_64 as well.  How can this solution be made more visible?  I searched several days and encounted several deadends before finding this thread.
Solved my problem with the simulator on Ubuntu 11.04, Design Suite 13.1
thanks !
Dag
Visitor inye
works for Ubuntu 11.04 with ISE 13.2
but files are in another directory with the command: "locate libstdc + +" found them.
Newbie mateevici
Thank you very much!
I've been hitting my head against the wall all morning to fix this problem and you solution did the trick!
By the way, it works on Ubuntu 11.10 and ISE 13.4.
Visitor lyttlec
This fixed all my report problems for 10.1 - 13.4
But on 13.3  (and Ubuntu 11.04)  I now get the following error when using the simulator
gcc: isim/precompiled.exe.sim/ieee/p_2592010699.lin64.o: No such file or directory
gcc: isim/precompiled.exe.sim/ieee/p_3499444699.lin64.o: No such file or directory
ERROR:Simulator:861 - Failed to link the design
It does not look like the libstdc++ issue, right ?
Any idea how to solve this bug ?
Dag
Newbie gautam_bhat
Go to process properties and remove incremental compilation. Compile. The problem should go away. Then enable it for faster builds.
Newbie kiredeid
This worked like a charm. Thank you so much!
Newbie psilord
This worked for me on Linux Mint 15 running on an x86_64 box with ISE 14.7.
I realize that shipping a binary only product with system libraries embedded in it is difficult in the linux world. Thank you for supporting ISE Design on linux!
The unlinked way by moving libstdc++* into orig folder resolved my problem on ISE14.4 on Opensuse12.*
Actually the unlinked way will cause iMPACT fail to launch without any errors and infors explicitly
Visitor aaron1
This worked for me with Error: SIGSEGV 776.
I am using VM Workstation 10 with ISE 14.3.
Thanks _bhat
Participant vbarsoum
The only solution I can find to solve this is to keep switching between Xilinx "libstdc++.so.6" ans system "libstdc++.so.6", and that's a very bad solution for that. moving Xilinx "libstdc++.so.6"  to "libstdc++.so.6.orig" will cause other problems as well.
I am using ISE 14.7 with opensuse 13.1.
I finally found a solution for this complicated problem on opensuse 13.1. I simply install another user interface called "Enlightenment". This user interface doesn't require (libstdc++) too much, so most of the applications can work.
